Every week there are new posts about someone hearing noises from their suspension and/or front-end. I wanted to create a master thread to organize this so we can compare notes and help each other. I know some of those sounds are normal and some abnormal, so hopefully we can figure out which is which.
What noises are normal?
Air suspension - some air noise when raising and lowering vehicle
Hydraulic roll control - fluid moving through the system
Dampers - compression makes a thump sound
Friction brakes - creaking noise as the brakes compress/release
Jounce - thump, hiss sound as suspension travels/compress
Air compressor - motor and air hissing noise
HVAC - motor whines, vibrates floor, seat, steering wheel (Gen1)
What noises are NOT normal?
Half-shaft
rattle, creak sounds
fix: replace half-shaft
Subframe
thunk, clunk, creak sounds
fix: typically fixed by replacing older welded subframes with cast ones
Hubs
creak, clunk, thunk sounds
fix: typically fixed by replacing hubs
Dampers
clunk, thunk sounds
fix: typically fixed by replacing dampers
Jounce
squeak, chirp sounds
fix: replace jounce assembly as they can get over extended and wear over time
Bolts/Washers in the front end
creak, tick sounds
fix: torque to specs, replace washers
Drive unit
creak, grind, rattle sounds
fix: typical fix is to replace the drive unit
CV Boot/Joint
click, creak sounds
fix: typically fixed by replacing/repairing cv boot or replacing entire joint
There is still a whole lot to be mentioned here and please anyone can feel free to what he or she thinks should have been on the list.
Half-shaft
Subframe
Hubs
Dampers
clunk, thunk sounds
Jounce
creak, tick sounds
Drive unit
CV Boot/Joint
click, creak sounds
