R1T Underseat Partition Template
I put together a quick template for a partition to insert into the slots in the rear underseat storage compartment.
I have PDF file for legal size paper. You don't need a cad program, just print it out and you will have a perfectly sized template that you can tack to a plywood panel and cut out. Thickness should be no more than 10mm (~3/8").
Ended up laser cutting these from a high quality foam board. Bonded two 1/8" layers together. Stiff, strong, and super lightweight.
I don’t see this mentioned often, but people...
I have been taking a look at the new Rivian...
