Solved: Connecting Rivian to HomeLink with Security+ 2.0 Liftmaster / Chamberlain Opener
RoseR1S
2025 R1S Tri Motor
Over the weekend, I was finally able to solve the connectivity issue I was having, for the Rivian R1S to get setup with Homelink for Chamberlain / Liftmaster. The issue as far as I can tell boils down to whether or not your garage door opener utilizes Security+ 2.0 but it may be more nuanced than that even with the specific version of your opener. For me the solution was to get the Homelink Compatibility bridge.
http:// www.homelinkestore.com/Products/HomeLink-Compatibility-Bridge-Kit.html
Once I set that up it worked right away. Process was pretty straightforward.
• Start the rivian door setup. Instead of using your normal remote use the Homelink compatibility remote.
• Plug the compatibility unit into an outlet near the opener.
• Press the learn button on the garage door opener
• Run back to your car and go through the three signal sends in 30 seconds.
That was it. Hopefully if you are stuck and told by rivian your opener is not compatible this will work for you as well. Good luck.
I don’t see this mentioned often, but people...
I have been taking a look at the new Rivian...
