A friend noticed on the black trim pieces along the rocker panel of his truck, that there seems to be bloches, stains, or could even be dried on paint. At this point my regular car wash didnt work, tried dawn and nope, even some murphys oil soap.
Before
So I gave him a few tips I saw online and this one, I got these from a recommendation on Rivian FB page I believe. They are wonderful as I've seen a lot of people talk about how effective it was for a similar black trim with similar staining issues.
CERAKOTE® Ceramic Trim Coat Kit -... https://www.amazon.com/dp/B07SHJVK4G?ref=ppx_pop_mob_ap_share
Cerakote Trim Coat ($16 from Amazon) is a ceramic coating for plastics. You just have to follow instructions and wash with dish soap using a soft sponge or microfiber towel to strip off all grease/grime, or wax. If that isn't enough, rubbing alcohol should do it. Once dried the plastic trim may look dull or faded. That's where Trim Coat comes in, to restore that deep rich like-new appearance. And it will stay that way through more than a few summers; unlike products like 303 or Armor-All (which would only last a few weeks).
After
There are other helpful options I saw, like magic eraser. Not as gritty as a Brillo pad but an abrasive pad nontheless. The plastic trim is textured with peaks and valleys. Wiping with an abrasive pad is just like sanding drywall with a fine grit sandpaper. You're sanding down the peaks (as well as the outer layer, which can make UV damage more severe).
Before
After
