Maintaining Your Rivian R1S's Battery Health: Best Practices and Tips
The Rivian R1S comes with advanced battery technology, which is a crucial component it possesses as a modern EV. To ensure optimal performance, range, and longevity, properly maintaining the battery is essential, and this article is a guide with the best practices and tips on how to maintain your R1S's battery health.
BATTERY DEGRADATION
Battery degradation is the gradual loss of a battery's capacity, efficiency and overall performance over time. Battery degradation is a natural process that affects all lithium-ion batteries. Some factors that contribute to degradation are charge cycles, depth of discharge (DOD), temperature extremes and age.
BEST PRACTICES FOR BATTERY MAINTENANCE
1. Avoid Extreme Temperatures: Park in shaded areas, use thermal management systems, and avoid leaving your R1S in direct sunlight for extended periods.
2. Charge Wisely:
- Avoid overcharging (keep charge level between 20% and 80% if possible).
- Use Level 2 (240V) charging for efficient charging.
- Avoid rapid charging unless necessary.
3. Monitor Charge Cycles: Limit deep discharges (below 10%) and avoid frequent rapid charging.
4. Update Software Regularly: Rivian's over-the-air updates often include battery-related improvements.
5. Drive Efficiently: Maintain moderate speeds, accelerate smoothly, and use regenerative braking.
6. Avoid Extreme Depths of Discharge: Try to keep the battery level above 10%.
7. Store Your R1S Properly: If storing for extended periods, charge to 50% and store in a cool, dry place.
ADDITIONAL TIPS
1. Check Battery Health Regularly: Can be done using the Rivian app or consult your owner's manual.
2. Avoid High-Speed Charging: This can cause heat buildup unless it's necessary.
3. Plan Long Trips: Charge strategically to minimize battery stress.
4. Avoid Extreme Altitudes: High altitudes can affect battery performance.
5. Keep Your R1S Clean: Washing and cleaning your R1S regularly can help maintain battery cooling efficiency.
RIVIAN'S BATTERY WARRANTY
Rivian offers an 8-year, 175,000-mile battery warranty, ensuring your R1S's battery will retain at least 70% of its original capacity.
Some FAQ's includes:
Q: How often should I charge my R1S?
A: Charge as needed, but avoid overcharging.
Q: Can I leave my R1S plugged in overnight?
A: Yes, but set the charging schedule to avoid overcharging.
Q: How do I check my R1S's battery health?
A: Use the Rivian app or consult your owner's manual.
Important Things To Note
1. Avoid extreme temperatures and depths of discharge.
2. Charge wisely and monitor charge cycles.
3. Update software regularly and drive efficiently.
4. Store your R1S properly and check battery health regularly.
These are some tips and best practices that'll help maintain your Rivian R1S's battery health, ensuring optimal performance, range, and longevity.
This is a great thread buddy. A lot can be learnt here for R1S owners and Rivian owners in general. Impressed with this page so far
Its a great thread indeed J. There are so many threads on here that Rivian owners can learn from. Awesome site
This would be super helpful for me as a new owner and member. Thank you for sharing
