So if you're looking for a bed mat that was rubbery and sturdy, or you were dying for a custom fit bed liner solution that stops things from sliding around and is super strong, you could go for this alternative. The plastic on this one is already chipping from light use and it's also water proof as well.
It has been trimmed to fit and it took only like 15 minutes to cut it up to fit with a new utility knife. It's like the easiest project you could ever carry out. And the excess at the bottom just rolls up nicely when you close the tailgate and provides "spring" to help open the tailgate as an added benefit.
Until Rivian makes a custom fit liner like this, this seems like the best alternative out there. Would be sharing some more pics below.
Above is the front. Just trimmed straight across leaving 3.25" between the wheel well and the front of the bed. Probably closer to 3.35" but please do well to measure.
