jbrezy_r1t
I picked up the tailgate pad for the Scottsdale store yesterday and was able to install it in under 5 minutes. It has 4 adjustable straps that go around the tailgate to hold the pad into place. The pad itself made from a combination of Nylon Ripstop, Neoprene and EVA Foam materials and is a lot thicker than I thought it would be. I do like how you can still see the tail light through the mesh part of the pad and it has a reflective RIVIAN logo too. The buckles onto of the pad have a good amount of adjustability to hold a wide range of bikes. As you can see from the pictures it’ll hold a fat e-bike frame as well as a standard mtb frame. At $200 it’s a little pricey but the quality is great and the ability to retain the tail lights make it a better choice than going with a non-Rivian branded bike pad.
PROS:
- easy install
- holds 4 bikes
- retains use of tail light
- reflective RIVIAN logo
- best fitment for R1T
- thick padding for tailgate protection
CONS:
- little pricey
- a little bulgy on the sides
PROS:
- easy install
- holds 4 bikes
CONS:
- little pricey
