Rivian Dual Power Distribution Switch: A potential game changer
Everyone who know me, knows I'm a full time RVer. I go from park to park with my Rivian and and most parks have an electrical pedestal that has both 50 and 30 amp connections. Since the Rivian work off the 50 amp. You can also hook an RV to the 30 amp while the rivian is charging but this requires a physical changing of the connection.
A week ago, I met someone who made a Dual Power Distribution Switch that swaps the 30 and 50 amp connections. First iteration by the flip of a switch. Thinking the next generation will have Bluetooth control. Conforms to National Electrical Codes. NEMA approved enclosure for wet locations. Not UL listed. 80amp rated relays. Switches fast enough where most electronics will not be affected. I attached a photo of prototype.
Unlike Lectron, Splitvolt, and Neocharge, this is not a socket splitter. This physically switches the two inputs and the two outputs. If you use a "dog bone" to charge the EV off the 30amp circuit, your rate of charge is the same as if you were using the 15amp circuit. So, to keep from continually switching/making physical connections, I can just flip a switch and the other vehicle won't even know that it lost power.
In case you were wondering if you could switch the plugs at any time, yes, you could. You could actually just switch the plugs all the time. This Dual Power Distribution Switch allows for easy switching without having to reset clocks, wifi, and other electronics. In the next generation you won't even have to go outside to the pedestal. I find the switch very useful and was hoping someone else could benefit from it.
