Morgan
- Dec 18, 2024
- IG Page
- Visit Instagram
- 2023, Rivian R1T, white & Blue
I just wanted to share a short article about the wind noise I've been hearing in the cabin. I'm not the only one and there are lots of mentions of it here and on other forums with different issues and fixes... this one is mine.
Like many, the bulk of the noise was coming from the triangle area of the passenger side door. Looking externally, it all looked fine, and identical to the other side, and the noise didn't exist the week of delivery.
TLDR; It was the trim pieces around the triangle window, but the window itself is solid and sealed. They will replace the trim piece with better tape, so my fix is temporary but very effective.
Here is the trim piece that was causing the issue for me, I noticed it was ever so slightly unseated from the rubber gaskets, and then when I pulled slightly the whole piece came out...
Even better, you can see there is only one TINY piece of adhesive tape on this piece, which really makes zero sense...
So after reporting the issue to Rivian, and not being able to wait for them to fix it before my trip this week... I put a temporary fix in place, and I can report that it works wonderfully.
I hope this helps others resolve their
issues as well. Note that ANY of the trim pieces on any side could be loose and they will also cause the issue, this is why I also taped down the top part as it was slightly loose as well.
