- Nov 14, 2024
- R1S Rivian Blue
For new Rivian owners looking to use all-terrain mode, choosing between 22-inch sport wheels and 20-inch all-terrain tires comes down to comfort and off-road performance. The 22-inch wheels look sleek but can feel stiff, especially on bumpy roads, even when you set the suspension to soft in All-Purpose Mode.
Switching to all-terrain mode helps smooth things out, making the ride much more comfortable over rough surfaces. However, these larger wheels don’t handle airing down (lowering tire pressure) as well for off-road grip. If you’re hitting trails often, the 22-inch tires might not give you the flexibility or cushion you need for a great off-road experience. Keep the suspension at a medium height for a balanced ride, as max height can make things less stable on uneven ground.
The 20-inch all-terrain tires are a better pick for new Rivian owners wanting versatility in all-terrain mode. These tires handle rough terrain more comfortably and allow you to air down to lower pressures, like around 20 PSI, for better grip on loose surfaces. This makes a huge difference when tackling dirt, gravel, or mud. Just be cautious—don’t go too low on pressure or drive aggressively, as you risk popping the tire off the rim.
The owner’s manual suggests 30 PSI as a safe minimum for off-roading. Compared to the 22-inch wheels, the 20-inch tires feel softer and more capable on trails while still performing well on pavement. For the best ride, adjust the air suspension to a medium height to maintain control and comfort without sacrificing stability.
