Helpful Solution to Rivian Cabin Noise From Outside Windows
I recently watched this 8 month old video that I wished I had watched a lot earlier. I have had some wind noise issues from the triangle windows in the front driver and passenger side. And I know it has been an issue for many over the years.
I haven't carried out same solution but I know of someone who has done the same thing as the video and bought the 25 foot rubber material. The interesting part is, you only need about an inch and a half for each window-but it was not that costly and you could have it for other uses down the road.
Upon installation, which for someone not too skilled, it took about a minute or two max to do on each side. The results were fantastic. It deadened the sound so much and now she does not feel a slight draft of cold air emanating from those triangle window areas. If you are having issues still, I think this might be a helpful thing for you to perhaps try. I attached a link to the YouTube video below.
