- Oct 20, 2024
- R1S
My R1S is what I use for almost all city/daily driving. Leaving the mall last week, the car started making an awful sound, and I could feel a rubbing and the car fighting against me. The sound was like metal rubbing on metal, and this is what I ended up finding.
Attention to screw at "12 o'clock." At first, I didn't know what it was. Later on, I found out it's a "torque to yield" bolt, and they are usually minimum bolts. How did this screw come loose?
My initial thought was to jack the car up and tighten it, but this seemed like a major problem. Heard they're aluminum bolts, and most of them can be torqued twice before they need to be replaced. It's hard to tell from the picture, but a friend said it's an aluminum bolt, and since the head is partially rounded, I'd swap it out for sure.
Told me it's probably just a case of the bolt not being torqued to spec when the vehicle was assembled. Not good, but also not disastrous since there are two more bolts that hold that CV joint into the hub. Personally, I'd get a new bolt, install it, and check that all the other ones are torqued to spec.
