Proactive Replacement of Rivian 12V Battery
After reading the various reports of Rivian owners being stranded when their 12v battery died, I have been considering replacing mine proactively. I decided to ask Rivian to confirm if my R1S has one or two lead acid batteries. While support could not answer that question (after initially stating that all Rivians have 2 12v batteries), they suggest I let Rivian perform this service.
Was trying to book a service appointment when I found out that Rivian will only replace the 12v battery with a similar lead acid battery for about $300. I suspect this would be a foolish replacement. Instead, I'm considering replacing the 12v myself (well, with my handy brother's assistance) with a lithium battery. Don't know if I'll be making the right choice by replacing with a lithium battery in hopes of avoiding a dreaded 12v battery issue? Or perhaps the 12v battery issues are related to the build date? Maybe Rivian received a bad batch of lead acid batteries?
Talked to some owners and someone told me that the 12v batteries are a weak spot on these trucks. Advised that I souldn't spend all the money to proactively replace it. I sould instead purchase a good battery bank. If/when it fails, I can jump the R1S back to life and then replace them. The aftermarket lithium LifePo4 batteries are pretty good. One vendor claims to have heating. For me, as long as they have a bms and provisions to warm them up when it's really cold (LFP can be damaged by charging below freezing though they can still be discharged).
I believe this is a valid concern. Just better to be prepared if there is a failure because even if you spend the money to replace, there's no guarantee that you won't have a failure.
