R1S Steering Wheel Shake/ Vibration at 65 mph and Over
So I recently had this issue and found out a little tip that was helpful and felt it would be nice to share. I was heading out of town last week and swapped the rear tire to the front on the passenger side (tread getting low, a bit more tread on the rear so wanted that for conserve mode)
Pretty bad vibration at 50mph+. It calmed down around 60 or 65mph, and gets substantially worse at 80+. My solution was going whole hog in all-purpose from a red light. That calmed the vibration down a whole lot.
I'm thinking the rear is wearing tires unevenly over time (the suspect tire came from a really "squeeky suspension side" i'm going in for in January). You move them to the front and feel the uneven tread depth. You're wearing off the difference with some "spirited" accelerations.
I'm actually getting a new set of 4 mounted before the weekend. I threw the suspect tire on a bubble level and it's definitely no longer balanced after 38k miles. Hopefully someone could find this helpful.
