- Nov 14, 2024
- R1S Rivian Blue
One of the first things I did on getting my R1S was set up the drive cam. I had the drive and took it to the service center when I took delivery last year so they could walk me through setting it up.
Worked fine, but it stopped recognizing the drive at some point, so I got a name-brand (Transcend) drive to replace the no-name one.
I set it up, but later realized that it wasn't recording. So I googled "Best drive for Rivian drive cam" and it said this one:
Still didn’t work. So I went to "set up drive cam" and it goes through the format & test routine and says I'm good to go. But the screen still says it needs to be set up.
I repeated same procedure several times, each time it says the format & test is good, but it doesn't take.
So the fix I got was, I let Rivian format the drive. I'm using 128GB USB-C flash drive. I also did a reboot for the vehicle (hazard button and left toggle on the left-hand side of the steering wheel) by keeping both depressed until the screen starts to reboot. This helped me with my fix and I hope it can help someone out there too.
