Rivian R1S compatibility issues
The issue of compatibility has been reported by some owners, especially in the Gen 2 model running software version. A few of the issues experienced by some owners include
1. USB-C Port Issues
2. Mirror Unfolding
3. Camera Adjustments
4. Kneeling
5. Audio Quality
6. Passenger Door Lock
7. Interior Lights
8. Vehicle shutdown
9. Autopilot
Troubleshooting Steps
To resolve the compatibility issues listed above, here are some troubleshooting steps you can take.
1. USB-C Port Issues: A simple check if the USB-C cable or the device is compatible or a software upgrade can help to fix this.
2. Mirror Unfolding: Try to check for obstructions as that can affect the mirror unfolding feature.
3. Camera Adjustments: Your camera settings can be adjusted through the touchscreen to resolve this issue, and if it doesn't work, a vehicle restart can be advisable to sort out the issue.
4. Kneeling: Check your suspension settings and always ensure proper clearance too.
5. Audio Quality: Make sure vehicle software is updated to the latest version and regularly check your audio settings too; make sure they are all in order.
6. Passenger Door Lock: Check your door settings to ensure doors are properly locked.
7. Interior Lights: Lighting settings should be checked to see if they are all in order, and if not, they can be adjusted from the touchscreen.
8. Vehicle Shutdown: Check vehicle settings if everything is in order, as that would help for a smoother shutdown.
9. Autopilot: A simple software upgrade can help to resolve this issue.
Most of the compatibility issues fellow R1S owners face are as a result of software glitches. One of the basic maintenance advices is to always make sure that your software is up to date. So checking for regular software upgrades and upgrading to the latest software versions is pretty essential in helping owners to avoid compatibility issues such as these.
