- Nov 14, 2024
- R1S Rivian Blue
When I first got the R1S, I couldn't connect it to our house mesh wifi which is a Deco M9 Tplink system. It could see some networks nearby, but not mine. I've seen some people online with similar problems, but the solutions ranged from add a dedicated router to use the 5G connection for anything needed. It seems it was that my router wasn't showing the encryption protocol the Rivian's want. I found the solution so I wanted to document it here for someone else. Even if you don't have a Deco router there might be something similar for your router.
Issue
The issue is that the Deco M9 has a great app and automatically updates the firmware, but at some point it stopped updating automatically and it didn't have the WPA2 AES Encryption in the firmware until after that time. I found a number of other people with various vehicles on the web with the same issue.
Solution
The solution is to update the firmware manually. It sounds worse than it is. You basically go here: https://www.tp-link.com/us/support/faq/1599/ and follow the instructions for the version of router you have. You download the update tool and then download the lastest firmware (some have to update in succession multiple versions with the tool if they get an error jumping versions i.e you must upgrade to v2, 3, and 4 instead of going right from v1 to v4.
Updated it in about 10 minutes and the Rivian saw it right away. Just wanted to share this tip here and hope it helps out someone out there.
Issue
Solution
