Humid Air Causing Fogging on Rivian Interior Glass Surfaces
During this winter, it's common for owners to experience foggy glass surfaces, and it can be pretty egregious. When the HVAC is set to heater and defog, the issue is reliably reproduced when it's relatively cooler outside. This is kind of a safety issue, as it can pop up 5 minutes into a drive or 30-60 minutes into a drive. A friend of mine recently experienced this, and I was able to offer her some advice from my own previous experience.
Here's what her car looked like. I experienced the same issue last year while we were on a road trip under very specific conditions - incredibly high humidity, low air temperature (40s, if I recall correctly), and it was especially an issue if the car was preconditioning for a DC Fast Charger. I assumed that the temperature and humidity combination, plus preconditioning the battery, somehow made the AC compressor not function at 100% for in-cabin climate usage. I seem to remember that if I cancelled the destination to the fast charger (and thus stopped preconditioning), it went back to normal.
Another tip for a better result is to turn on the recirculation feature, so that it's drying the same cabin air repeatedly. Also, be sure to check under your floor mats for wet carpet. There have been reports of AC system leaks, where the condensate drips back into the vehicle, saturating the carpet. If that happens, it's never removing moisture. To help diagnose the issue, look for condensate, or a lack thereof, dripping outside the car. These tips should be very helpful.
