Screen Protection
Screenprotech.com has this pre-cut screen protection kit with everything you need to install all 3 touchscreens for $60.
It comes in this nice cardboard tube so everything stays rolled up as it should. There was no need to let it settle flat when removing from the tube.
The big center screen was the biggest challenge because there doesn’t seem to be a way to lock it and cleaning/installing made the climate control and navigation go crazy the whole time. I suggest starting with the small backseat screen that you can lock from the main display. Use the solution VERY liberally as I went big screen down to small and learned my lesson along the way. Watch the videos and read the instructions carefully and it will come out fine. It does make a liquid mess, so be prepared to clean up quickly. Once installed it is transparent as it should be. Granted it is in my garage in dark mode, but I can’t tell a difference from before, and that’s a good thing. I’m not going to include pics of the screens installed because it really doesn’t show anything.
Hope this helps for those looking to get quality screen protection
