I no longer drive a Gen 1 Rivian but I thought it'd be cool to share this for Gen 1 users who might find it interesting. So, it's a beta app and works perfectly fine. Met someone who used it last Sunday when he let his phone battery die. It was a great backup.
If you can't get it to let you drive, or to do passive lock/unlock, then you can try to reboot the Watch. Also if you're on iOS 18, you may have different experiences. Others didn't have to reboot. This sets up in the truck just like a phone but shows up as a key card. You will need to be inside the vehicle to set it up as a key. Launch the app, and it will guide you.
testflight.apple.com
Important tip: You will need to log into your Rivian account on the Watch itself. If you use a proper password, that would suck a lot. Advisable to use 20 characters that are very random/complex. But you can use your phone and its password manager to share the info. Just put the phone by the Watch or tap it, when you are in the login prompt, and the iPhone will prompt you to enter or share the password automatically.
For those who might be wondering if it's a direct bluetooth connection, no, it actually isn't. The Rivian has many bluetooth radios/sensors, maybe five. It knows if the key is inside or not, and where on the outside it is. The sensors for PAAK are not at all related to the BT system for the entertainment system. Go to your BT settings when you are near the car and it is awake. You will see the expected "Rivian Camp Speaker" and "Rivian Audio." But you probably will also see a bunch of "Rivian Sensor 1" and other numbers. I think I've seen four but not sure.
TestFlight - Apple
Using TestFlight is a great way to help developers test beta versions of their apps.
